hooligan
Jul 24, 2013Explorer
I've not seen a layout drawing of the framing for any Georgie Boy- The side walls are constructed of 1-1/2inch square, welded aluminum framing, with block foam insulation between the framing.
Walls are bolted to the chassis. The cockpit area MAY also have welded steel framing at the firewall area.
A post on another site discussed a broken section of the frame and may give some insight.
Frame problem
Keep us posted, particularly if he comes up with new info...
Frame problem
38,782 PostsLatest Activity: Sep 10, 2026
