al_hillman
Mar 30, 2016Explorer
I have power in the coach.Everything works as normal except the generator and jacks. Just odd that both stopped working at the same time. The outside switch for the generator has a blinking red light when you hold it in to start position but the starter does not engage or click. The jacks are hydraulic and the light on the dash lights up but when you press the button to lower them nothing happens.I tested the 2 -6 volt batteries and have 12.6 volts. I checked the breakers in the coach and none were tripped.I don't see where the fuse may be for the generator or the jacks.
38,763 PostsLatest Activity: Dec 05, 2025
