enblethen
Feb 08, 2015Nomad
Go to your inverter/charger, there should be a large fuse in the 12 volt DC lines coming from the batteries make sure it is good.
Check your battery fuse in your 12 volt DC distribution panel.
Check your control panel to insure the charge is turned on, if there is an option.
Do you have a battery charger? This could hold you over until all repairs are made.
Yes, the refrigerator requires 12 volts DC for control and LP operation.
DC charger could have been fried.
I hope the "electrician" is paying for all the repairs!
Call Xantrex!
Call Xantrex!
