- Pirate1ExplorerThanks. The unit I was looking at was listed on rvtrader but when I called the "dealer" nobody ever returned my call. ???
- catldogExplorerWe have the same basic model,Bought our Journey in 11 with 38,000 miles,have 72,000 now, replaced tires, batteries, shocks and front end bushings soon will be replacing both windshields
seems in that era Winnebago didn't know how to seal around the windshields,thus causing rust on the frame.We enjoy ours, has a lot a room for the 2 of us. Have seen lately these models selling in the 35,000$-50,000$ range.jg - rgatijnet1Explorer IIIMileage alone is not a determination of the value of an RV. The fact that you are asking on this forum seems to indicate that you have limited ability to thoroughly check all systems in an RV, including the engine and drive train.
Perhaps the best thing for you to do is spend the money and have a COMPLETE inspection done by qualified professionals to determine the overall condition of the coach.
This will not only tell you the condition of the existing systems, it should also indicate what items need immediate service and what items can be delayed. It can also tell you if this coach has suffered any flood damage in the past.
The cost for the inspection may be offset by the money that you would save doing preventive maintenance on items that do not need it at this time. No use spending money replacing hoses and belts if an inspection indicates that the existing belts and hoses are in good shape. - FIRE_UPExplorer
mike brez wrote:
midnightsadie wrote:
I don,t let low bother me. sounds like a very nive rv.
:h
Mike, you beat me to it. Is that a code or what?
Scott - mike_brezExplorer
:h - wolfe10Explorer
ACDNate wrote:
FireUp. Air dryer attention? I have a 2008 Journey Cummins 350. More info on servicing the air dryer?
Yes, air dryers DO require periodic servicing.
Several options:
Rebuild with new filters
Reman from the factory that made it (best choice IMO as it replaces all valves, heater, etc in addition to the filters).
Replace with new (OK, but more $$)
Replace with "made to replace ...." Often cheap Chinese knock-offs. NOT worth the risk to your air brakes and suspension components IMO. - midnightsadieExplorer III don,t let low bother me. sounds like a very nive rv.
- mike_brezExplorertime to service it then
Google and YouTube are your friend - ACDNateExplorerFireUp. Air dryer attention? I have a 2008 Journey Cummins 350. More info on servicing the air dryer?
- FIRE_UPExplorer
Pirate wrote:
Know anything about this model? Mileage is almost too low. Cat 330HP?
Pirate,
In those years, around '00-07 or so, the Horizon, Meridian, Vectra and Journey were top sellers for Winne and Itasca. Thousands of them, even the older ones like what you're looking at, are still running down the road. The subject of ultra low miles on an older coach comes up on a semi-frequent basis and, as usual, there's debate on each side as to run away from one or, jump on the deal.
I myself, have never worried about low mileage, in an older vehicle, even a motorhome. Sure, there would be concerns about seals, hoses, belts, tires, and a few more things that can "deteriorate" over time. But, most of those are going to deteriorate even with more miles so, to me, again, no biggie.
You have a stout, well built coach there. If it does have the CAT 330HP, it's gonna be the 3126 version. Those engines ran for years and years. change the oil and filter on a frequent basis and, you're good to go. There's lots I could tell you to check out but, in short, Winne adheres the fiberglass roof to the coach along both drip-edges on each side of the coach, just below the roof radius.
That glue/caulking/adhesive joint, has potential for breaking free over time and, when that happens, you will have sections of the fiberglass that no longer is held in place. That is NOT GOOD. So, one of the first things to check out would be that roof-to-gutter seam, for the full length, on both sides for stability and attachment. The way you check it is, get on a ladder and of course be careful, and carefully press on the fiberglass just above the caulking joint. If there's any deterioration of that joint, the fiberglass will press AWAY from the caulking. You do that same test, for the full length.
If you find large, long sections that have broken away, you've got a bit of work to do. It's not a fun job getting all that older caulking/adhesive out and getting the area prepped for new adhesive/caulk.
Anyway, there's that. Of course, all the rest of the roof caulking on all the vents, front and rear cap joints, antenna seals and all that. It's a rear radiator coach so, the clogging of the radiator and CAC fins due to debris, dust, leaves, and more due to oil mist from the blow by tube, is a semi-often occuring event. Many, many threads on here and other RV forums that talk about that situation.
Of course tire DOT dates are important to see just how old those tires are. The fit and finish of most of those era Winnes was pretty darn good. Not too many reported issues of anything inside the coach falling apart. Many of that era Winnes and Itasca Diesels came with a 1500 watt Inverter/Charger that would only charge the HOUSE batteries when on shore power or generator power. So, folks have taken it upon themselves to install a very cheap and effective item called the "Trik-L-Start" that will link the chassis batteries to the house batteries for shore power charging.
Typically, those coaches would also have a super heavy duty, "dual" duty solenoid that had two jobs.
1. When the Auxiliary Battery Boost toggle on the dash was pushed, that toggle would energize that dual duty solenoid to link the house batteries with the chassis batteries to get augmented power for cranking the engine.
2. The second duty of that solenoid was/is, when the engine starts, via the ignition system, that same solenoid is energized to link the alternator to the house batteries for charging, while driving down the road. So, you can check out those systems too.
Things like water pumps, furnaces, lights, and all that are self explanitory. You'll also have a "basement A/C" unit on that coach. You will NOT have any roof air units. The Basement A/C unit takes care of both cooling and heating. About 99.9% of the folks that have them, like them.
Again, I could go on for pages but, you get the point here. A good, thorough check out of the air system to see if the compressor builds pressure to cut-off, around 125 psi, in a reasonable amount of time, usually 0 to 125 psi, at high idle, (around 1000 rpm) in about 1-2 minutes. Your "Low Air" buzzer should cease at or near, 60 psi. Your emergency or, "Parking Brake" auto-activates at or near 30-45 psi. You WILL NOT be able to release that parking brake, 'till you have over 30-45 psi.
On a coach that old, and if no one's paid attention to it, you may need the air dryer serviced. Not a big deal. The kit is around $130 plus or minus. You should have an HWH leveling and slide system on that coach. The parking brake is the interlock for that leveling system. If it's not engaged, your HWH leveling system will not work. Conversely, if it's disengaged before the store button is pushed, the system will automatically start to retract the jacks.
So, you've got some things to check out. They're nice coaches. We see many, many of those older Journeys on the road quite often.
Scott
