enblethen
Feb 08, 2015Nomad
Connect the charger to the coach batteries.
The chassis battery may or may not charge from the coach system. You may need to run the rig to get the chassis battery back up.
If the tech connected it up correctly, the inverter charger should be working unless there is a problem with it or the DC fuse.
