DSDP_Don
Feb 08, 2015Explorer
This post is getting confusing again. If the transfer switch was fried by the electrician and everything else was working, including turning on the inverter and it was inverting, why is there now talk of other issues and battery chargers.
If the electrician fried the transfer switch, ALL he had to do to get you operational, while the transfer switch was on order, was to connect the shore power to the output side of the transfer switch. After that, everything in the coach would run as normal. The transfer switch is ONLY there to transfer power between shore power and generator.
