Canadian_Rainbi
Feb 08, 2015Explorer
TTitans1 wrote:
I also have three batteries for the coach so I am going to get a charger for sure. Does it matter which battery I connect to? Should I leave it on since my inverter/charger is not currently hooked uo to charge the batteries? I have cranked up the RV twice now in the last two days as it seems the solar panels I thought would keep the batteries topped off are not able to do that (maybe because it is cloudy )?
What do you think?
We have 420 Watts of solar panel and even in Mexico sometimes have to revert to the Xantrex charger, so unless you have some pretty awesome panels they won't be supplying enough. Most people (including me!) tend to expect too much from their solar panels.
What size charger did you buy--how many Amps?
If you can, connect the charger to the same terminals that the main battery cables are connected to. In the short term, connecting to one + and one - will be fine.
Once you get the House batteries charged you should connect the charger to the Chassis batteries to top them off. There will always be some drain from them--smoke detectors etc. On ours, they (the chassis batteries) also power the slides which takes a lot of current. Then put it back on the house batteries.
