- If you look closely, it usually has the arrows showing which way to turn them. BUT, I have found that after years of use, the Valve is worn out and needs replaced, because you cannot adjust them. Doug
- IvylogExplorer IIIMost adjustable pressure regulators increase the pressure when you turn the adjusting screw CW and decrease when turned CCW. If you cannot find an adjustment I would decrease the air flow by clamping the supply line until the slide moves slower.
