g_sturgill's avatar
g_sturgill
2000 rexhall Aerbus brakes
Hi all, on a 2000 Aerbus diesel pusher w Spartan chassis, is there a hydraulic component used in conjunction with the air brakes? I can't find a reservoir for fluid, and I'm getting nervous. The brakes seem to be OK, however.
Thanks, g
1 Reply
  • I had a 2001 Aerbus 3955XL on Spartan chassis and a ISC Cummins. All air brakes on that, no fluid to worry about.
    Abs brakes, all drum.
    Yours is probably the same. You can call Spartan. Have the last eight digits of your vin, and they will tell you anything you want to know. They are wonderful.
