I have a 2000 Fleetwood flair 31a with a ford v10, I move the shift lever to D and the trans does not go into gear. also when I move it to pos. 1 and 2. when I go to park it goes into park. I checked ...
I would disconnect the cable at the transmission and have someone move the shift lever from park to 1st gear to see if the cable moves freely with the proper range of motion at the transmission end, if not move the wire inside the cable that you disconnect from transmission end by hand and see if it moves freely, if it does you know the problem is up at the shift lever. When you move the cable end by hand will it go into Park and the rest of the gears?
