- TNGW1500SEExplorerGot an update?
- hilldudeExplorerDo a google search on the problem.
- hankoExplorer
DFord wrote:
FORD NEVER MADE A 2005 model year F-53 CHASSIS.
Production of the 2004 model year was extended to December 31st, 2004 and the 2006 model year was moved up to began on January 1, 2005 instead of the middle of the summer.
You will never find a VIN number showing the 2005 model year for an F-53.
well thats nice to know, but that doesnt really help the guy out does it? - DFordExplorerFORD NEVER MADE A 2005 model year F-53 CHASSIS.
You will never find a VIN number showing the 2005 model year for an F-53. - GermaniaExplorermy 2005 chassis (ford) has the 4R100 transmission
- tderonneExplorerDoes moving the shift lever into "1" or "2" change anything?
4th gear is the default gear, sure it's in 1st?
If you lose one solenoid, it'll still have two gears. It never shifts at all, right?
Reverse work? - TNGW1500SEExplorer
rcevans wrote:
If I added fluid as a precaution and it is overfilled will that make it squeal an slip?
Do not overfill it. Have u checked it? What color is it? Does is smell burnt? - rcevansExplorerIf I added fluid as a precaution and it is overfilled will that make it squeal an slip?
- rcevansExplorerAnyone know a good honest tranny person in Lakeland Fl.
- rcevansExplorerDid a 30 min reset no luck.
