wrrn73
Jun 26, 2018Explorer
2000 Winnebago front heat/AC problem
When I took my 2000 Winnebago on Ford chassis out of storage this year the front A/C vents are stuck in the def/floor position. Also the heat won't shut off causing the front A/C not to work. I am thinking it might be a vacuum issue but not sure. Has anyone else had this problem and if so where do I look to fix it? TIA
