grinder613
Oct 02, 2013Explorer
On my 1999 E450 chassie a critter chewed on the plastic vacuum line at the intake manifold exit and the check valve was malfunctioning. The check valve and canister are buried behind the heater/ac on the pass side. To get at the valve you have to drain the ac and remove the components. I made it easier on mine. I rerouted the vacuum lines and repositioned the valve and canister behind the passenger lower dash panel. If you look on youtube, some guys cut a hole in the inner fender to get at the canister and valve. My method is easier.
