overdrive75 wrote:
fourthclassC wrote:
As a 2003 Winnebago mini (24V) owner, I want to warn you about the sealing of the corner molding on the wall area over the cab doors. This molding has not been sealed at the factory as seen by myself and one other member with the same rig. Also look carefully at the molding where it curves up around the corners of the cab over area.
Can you explain where these areas area little better, maybe a picture?
Same here ... a picture would be super helpful.
I have a 2005 Itasca 324V and am concerned about this area of the cabover area, too.
