bobndot
Aug 12, 2020Explorer III
Can you follow the cables under the MH from the converter area or from a battery cut off switch ? The negative wire is normally grounded to the frame somewhere near the battery.
places to look, crawl under the MH to look for a battery box along the rails, under the entrance step , inside a baggage compartment or under the engine hood. I would think in 2002 it had to be in vented spot due to the common use of wet cell batteries.
38,782 PostsLatest Activity: Sep 10, 2026
