Beverley_Ken
May 23, 2021Explorer
I’m quite sure that you will find what you need on the Winnebago site. I can’t see much difference in how the would changed wiring in our 06 And your 03.
For 12 volt, Winnebago uses white (mostly 14 guage) for negative/ground and and Yellow for the 12 volt positive. On the wires, they imprint a code number every 12 inches and list on their website what it is. I.e. I found an unused plug, checked the code numbers and it was for the optional FRS radio system. They have schematics that show roughly where how they are routed, left or right frame rail, MH body, left, right ceiling etc.
I believe that everything behind the cab cut-a-way is Winnebago wiring.
Ken
Ken
38,782 PostsLatest Activity: Sep 10, 2026
