brlowe
Jan 03, 2018Explorer
2002 E450 Superduty tires
I have tried searching and wading thru old and new info and I could not find the info I was looking for.
My Tioga 31W is in need of new tires. As it is 31ft class c it runs at max weight. I try to watch what I carry and have not had a blowout. I would love to get some tires with higher load capacity just as an added protection, not to carry more stuff.
I see the Continental Vanco four season tires have a nice high rating but will they work. Yes it is rated at 83psi but if run at 80psi it would still be more than my current tires. Will these work on the E450 dually rears with out touching?
What is the latest and greatest tires that everyone is using? I have been out of the loop for a while. I think this is my first post in many many years.
Here are the tires I'm looking at
VancoFourSeason The specs show it is 29.3" tall and 8.8" wide with a 3195lb rating at 83psi so running at 80 a little less
https://tiresize.com/tires/Continental/VancoFourSeason-225-75R16.htm
And the Michelin XPS Rib, specs show 29.4" tall and 8.7" wide with a 2680lb rating at 80psi.
https://www.tirerack.com/tires/tires.jsp?tireModel=XPS+Rib&tireMake=Michelin&partnum=275R6XPSR
I think the sizes are close enough that the higher rated tire should fit ok but wanted to know if anyone has run them. The Vanco tire is less money too for some reason.
Thank you
Thank you
