Lariat's avatar
Lariat
2002 Georgie Boy dark brown exterior color
I have a 2002 Georgie Boy motorhome. The exterior color scheme is a cream/white color over a very dark brownish color that has a touch of sort of a purple tint. I am trying to find the paint code for the dark brown color. Any help?? Any search tips.
Thanks,
Lariat
  • Hi,
    Not sure if this will help, but it might give you a step in the right direction.
    Our GBM is a 2005 model year, but used the 2004 color codes. I don't know how long those codes were used. I do know the numbers are Sherwin Williams codes.
    Our full body paint motorhome has the following colors:
    Beige metallic Code # MB-47134(y)
    Medium Bronze Pearl Code # MB-57763 0 (s)
    Sage Metallic Code # MB-53911 0.
    I believe the medium bronze is the darker brown in our color scheme, but it doesn't have a purple tint, so it's probably not the same.
    If you do find the codes, I can highly recommend PaintWorldInc.com as a highly reputable company with great customer service. They have various packages and products geared to the Do-It-Yourself-er, if you're planning on doing some touch up by yourself. They have products which help give a nice, smooth finish, 2-part spray epoxy clear-coat and a spray on "blender" which helps the new clear coat blend in with the old.
    However, with the metallic paints, plus a vehicle that has over a decade of exposure, the match will be "close" at best.
    Good Luck,
    ~Rick
  • I don't have your brand, but had the same issue. Just go down to the local automotive paint shop and they can get very close with there paint matcher. I did my all my doors and you can not tell the difference.
  • Not sure if any of the phone numbers on in the attached link will help:Coachman paint codes Coachman website seems to indicate they cannot help you with codes for years prior to 2003 -that a body shop will have to match for you. Another forum mentioned they found their color codes on the support pedestal for the driver's seat, some found the codes on cabinet doors, some near the breaker box.
