PalisadesExplorerJul 28, 20132003 Fleetwood Revolution - turn signal problemsMy turn signals and hazard flasher do not work today. I checked the fuse that the schematic shows as "Turn Signal 10A" and it is not burned out. That is in fuse/relay Box 1 in exterior compartment o...Show More
bobaExplorerJul 28, 2013i would check the bulb first(or the led) if that(they) have burned out, it can also do as you describe.
Related ContentFleetwood revolution coach batteriesFleetwood Angler wiringTiffin Phaeton or Fleetwood Revolution2005 Fleetwood Revolution Running Lights not working.03 Fleetwood Revolution - Delamination
