- DavidPExplorerDid you check the fuse from the battery to the converter? Did you reverse the polarity? First two things I would check.
- BumpyroadExplorerdo you have a generator? if not, what 120 volt outlets/appliances/etc. are powered by the battery with inverter? on my last MH only the front TV had 120 supplied by the battery.
bumpy
