macobbrvnet's avatar
macobbrvnet
2003 Honda Odyssey on MasterTow 77T
Have done some research on the MasterTow 77T that came with the RV I bought a couple months back. Need a vehicle to seat my family of 6 - Honda Odyssey is a good choice -from my research it looks like the Van will just barely fit on the 77T - literally 1/2" within specs +/- Anyone using this setup out there? 2003+/- Honday Odyssey on a MasterTow 77T?
Thanks
  • The Odyssey 99-04 is a great toad 4 down. You do have to run through the gear sequence properly before towing, and Honda wants you to stay at 65 mph or less.
    Fred
  • the guy i bought the RV from included the dolly...was going to try and use it if i could...sounds like might be better off to sell it and apply that $$ to set the Odyssey up for 4 down..thanks for the advice
  • The 2003 Honda Odyssey can be towed 4 down. Why mess around with a dolly?
    ~Rick
  • According to Master Dolly specs sheet, the 77T is not big enough to tow a minivan such as the honda odysssey. If you are going to go that big you will need the Master Tow 80THD to handle that much weight and size.
