bluwtr49
Nov 29, 2013Explorer II
enblethen wrote:
The frames are weaker. Cross bar is to prevent frame from coming together.
Make sure you put the bolts into the cross member.
I suspect there must be another reason....frames are definitively not weaker than the '97 since they share the same uni-frame construction. plus there is a crossbar on the tow bar if that were indeed the case.
Frames are massive, brackets are massive with gussets, four heavy bolts including the roll bar brackets seem that it would do the job without a cross beam. Can not imagine these things moving.
38,769 PostsLatest Activity: Apr 03, 2026
