- way2rollTrailblazerNot sure if the OP will ever return, but - all you need to do is check your specs and weigh your coach. A quick look at Coachmen's spec sheet for your model tells me it weighs in around 14k loaded with a 22k GCWR. With a 7500 lb hitch it looks like the max weight you can tow safely is in the neighborhood of 7500 lbs. Of course the best way to tell for sure is weigh your rig loaded for travel and subtract that from the GCWR. The amount you can safely tow is the LESSER of this number OR your hitch rating. Of course even if the number is within specs you should always have a supplemental braking system on the towed vehicle.
- dodge_guyExplorer IIProvided it has the Active Drive II it can be flat towed. I tow an Explorer that weighs 4500 lbs, 4800 with bikes and a full tank of gas. Does very well in the mountains considering it’s weight.
I also tow a 16 Ram Hemi crew cab with a golf cart. 6200lbs total weight. Tows it very well in the flat midwest. It will never be towed in the mountains. Jstensby wrote:
Can my 2021 Coachmen 32fs flat tow a Jeep Cherokee with proper transmission and drive
My question concerns the weight of the car towed
Thanks
Yes, no problem. Your rig has a 7500 lb towing capacity when fully loaded, both hitch and GCWR are rated for this. You'll want a toad braking system, but do your homework since there are no design or manufacturing standards I'm aware of that cover these systems.- bighatnohorseExplorer IIThat's called the "curb weight" - it's how much the vehicle weighs.
The Jeep Cherokee has a curb weight of around 4250 lbs. The Grand Cherokee weights much more.
Which transmission your Cherokee has is important. Not all Cherokees are suitable for flat tow. - jfskeetExplorerIf your Cherokee has Active Drive II yes, It its 2017 or older you need to have a kit installed so steering stays energized to stop the death wobble.
We towed our over Canada and Yellowstone to Glacier and Tetons with 8% grades with no issue
We have an 2018 Tiffin 34PA with V10 - Tom_BarbExplorer IIIf you have a transfer case lever that says High-Neutral - low you can place it in Neutral and tow with 4 down.
how well it tows is a different story. - wildtoadExplorer IIHard to know with no data. What does your mh weigh as setup for travel? What does the Cherokee weigh? Add those two weights together and compare to your motorhomes Gross Combined Weight Rating (GCWR).
My 2016 F53 V10 mh tows my 4900 lb Jeep Gladiator just fine.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
