pellifson
Jun 26, 2013Explorer
Thank you for your help.
The original owner repositioned the water tank, water pump and raised the benches to accommodate a wheel chair. I think one of the benches was actually taken out (along with the passenger seat). I didn't see how he had it configured. I'm the third owner. The second owner did some modification before I bought it.
The information you provided explains where it should be mounted but, I'm confused with the holes on the floor. Did the water lines originally run underneath on the outside? Mine were cut and run along the floor on the inside. They were covered with a molding that the last owner made. I don't see where they could have been run on the underside. My generator sits between the tank and the sink.
Dale
Dale
