nbkingExplorerOct 23, 20162004 BT CruiserJust purchased a 2004 BT Cruiser. The electrical outlets are not working. I tried to reset the GFI plug but nothing changed. I am having problems identifying which fuse to check to see if that chan...Show More
NCWriterExplorerOct 23, 2016If you have pressed the reset button on all the gfci outlets inside, check to see if there is also an exterior outlet.This happened to us with our class B Van. Called the factory, and they reminded us there was another one to check.
Related ContentWinterizing a 2004 BT CruiserGulfstream BT Cruiser QualityBT CRUISER 2004OEM Tires 2004 BT CruiserBT Cruiser cabover noise fixed!
