nbkingExplorerOct 23, 20162004 BT CruiserJust purchased a 2004 BT Cruiser. The electrical outlets are not working. I tried to reset the GFI plug but nothing changed. I am having problems identifying which fuse to check to see if that chan...Show More
avanExplorerOct 23, 2016I had that situation and could not track it down at first. Problem was with an external relay to the coach power disconnect switch.
Related ContentWinterizing a 2004 BT CruiserGulfstream BT Cruiser QualityBT CRUISER 2004OEM Tires 2004 BT CruiserBT Cruiser cabover noise fixed!
