rgatijnet1
Sep 20, 2018Explorer III
With my Workhorse chassis the brakes were great but it required FLUSHING the entire brake system and replacing the brake fluid with all new brake fluid. Just bleeding the brake fluid will not do it. It takes almost three quarts of fluid to properly flush all of the brake lines. This should be done every two years.
It is also required that you grease the slides with brake caliper grease to insure that they slide properly. This also prevents the calipers from sticking on coaches that are not driven frequently.
