garry1p
Apr 29, 2014Explorer
I suspect you have 2 problems.
1. You need to troubleshoot the loss of AC power in the coach.
a} Is it a coach problem or the CG pedestal?
b) Do you have a 30amp or 50 amp coach?
c) Start at the main breaker panel checking for incoming voltage.
2. Once you figure out the 120VAC problem you can start troubleshooting the generator. The problems may not even be related.
