TJHUB
Feb 26, 2018Explorer
ArchHoagland wrote:
4. The hydraulic levelers are slow.....Spray with WD 40 or use transmission fluid on them. I lube mine every year.
6. Do I want a Sewer Solution...... NO
8. The engine A/C doesn't work....can be anything from low on R134 ($20) to a bad compressor ($1200).
You should convert the transmission fluid to Transynd if it hasn't been done already.
Thank you. To be clear on the levelers, the rears don’t want to retract all the way without assistance from a prybar of some sort.
I will check into the trans fluid.
