Cooldj's avatar
Cooldj
2004 P32 condor, parking brake problem gray switch blown
Hi, I got a problem with this parking brake gray switch, I replaced that switch five times now, the switch blows, crack or pop the head resulting an oil leaking so engaged the parking brake. And it goes faster and faster I meen first time maybe a year before the problem and now, I just changed it run 45 min and blow  again.. I don’t know the problem if it is because too much pressure at the gray valve ? If it is how reduce that pressure .. I am lost on this one
   Help anybody
… Daniel
1 Reply
  • Check out iRV.net, there is a thread where people were talking about a better aftermarket part. Apparently the guy that made them appears to be no longer active.: But if you might be able to ask there and see if there is anything new to replace the original.
    link
