I have no current to the tv outlet. There is a fuse marked TV and it has 12 volts passing through it. I cannot find the inverter that would convert that to 110. Thanks for any help you can give.
Yeah, the GFI's are tricky little devils. Ours stops our kitchen outlet and makes us think the coffee maker is broken! We also have a 12V receptacle in our TV cabinet and the outlet there can be turned off by a switch near the antenna booster and night light. More than once we have strung an extension cord instead of remembering that little switch.
