fishinpole2
Jul 07, 2021Explorer
2004 Tioga 23E water pump
Hello all,
I'm new to this forum so hopefully I'm posting in the correct place.
Have a new to us 2004 Tioga 23E. I am trying to gain access to the water pump. Sounds like it is in the bottom of the bath sink cabinet but there is no way I can see to access it. Bottom of cabinet can only be removed if I disconnect all sink plumbing. There should be a better way. Please help me find it.
THANKS FOR YOU ASSISTANCE
I'll try answering and add more info
To Dutch_12678: There is no outside storage under bathroom.
ToDreWE: The bathroom under sink cabinet has a false floor about 1 foot above the motorhome floor. It is screwed in at all four corners and the drain and hot & cold water lines run through this floor. Also the "p"trap hangs down so if I remove the screws and attempt to raise this floor, it can only go up about 1-2 inches. If the pump is below this (and I think it is) I have to remove the sink drain/"p" trap and hot/cold water lines. Hoping for a better way.
To Tobydad: The freshwater tank is on the driver side and is located below a "jack knife" couch. To the left is a double door large cabinet. All of which move out with the slide. I can view under the couch and the pump is not there.
To bobndot: The water heater and bypass valve are on the opposite side of the RV. heater under fridge. Bypass under kitchen sink.
To Dusty R and garyhaupt: This small RV does not have a regular bed. Dinette is also on opposite side of RV. Space heater and electronics under dinette seats.
To IAMICHABOD: When I pull our only two lowest drawers, I see only the wheel well. No space for waterpump.
I WANT TO THANK ALL OF YOU FOR YOUR COMMENTS AND ADVISE.
You have me crawling around looking under every space I can get to. I am learning a lot about what I do have in this Tioga.
At this point I might attempt removing the false floor under the bathroom sink.
Thanks again.....
Thanks again.....
