tobydad wrote:
Usually the water pump is next to the fresh water tank. Maybe under a dinette seat or couch.
Yes, good thought , most are mounted low in the area between the water tank, water heater by-pass and the gravity fill port.
Even though its daylight it helps to use a flashlight.
You would be surprised at how much more you can see inside dark cabinets.
My pump is inside that 'area of space', but it's inside an exterior storage compartment having access via hinged door. The door is made from the same material as the compartment interior, black, making it difficult to see, it all blends in.
