btilfan wrote:
does anyone know where and if you can adjust it?
Your problem is simple. Alfa was only built for a few years and they had a multitude of design problems, including the slide mechanism and design. So, while we sold them for a year, I have not worked on one for almost 10 years. We decline to do service on them due to the problem with parts supply on Alfa parts. So, you will be hard pressed to find someone knowledgeable enough to help you out on line or at a service center. The only slide problems on Alfa's that I had to fix was the front main slide. That slide was the cause of most problems. Never had a problem with the rear slide. This is why your best bet is those Alfa forums someone showed you. Doug
