katleman
Aug 21, 2023Explorer
zigzagrv wrote:
Did you check your battery voltage? Had a similar situation once where after I would stop for a short while and when restarted, it would run rough and throw codes till I got up to speed. Turned out battery was bad and till the alternator built up voltage, this would happen. New battery solved the problem.
Battery is new this season, replaced proactively, not out of need.
The codes are thrown at idle, up hills, down hills, doesn’t appear to vary with load.
38,782 PostsLatest Activity: Sep 10, 2026
