dougrainer
Apr 19, 2018Nomad
On some slides in a wardrobe, you remove the Kick panel at the bottom inside of the base. usually this kick panel is carpeted and has just 4 or 5 screws holding it on and the motor will be behind that. When the room is extended, on the outside under the slide can you see a single gear track? IF SO, then the motor is located behind that kick panel. Doug
