I have it home and I am wanting to do some maintenance before I start using it. The roof looks really good like advertised being stored inside with that said I would like to clean and reseal it any recommendations on products to use? An earlier poster that has the same coach in a 38' says it has a TPO roof what is that?
There are no stains on on the roof but I would like to clean it and put new seal around all the penetrations. I would also like to put some seal on the joint where the roof meets the siding and around the windows what products do I use for this? Any online links would be appreciated.
I ordered a 9 gallon rolling oil pan when it comes in I plan to do an oil filter and oil change on the engine & the transmission and put in a new fuel filter. I worked as an equipment mechanic in my younger days so I plan this work myself do some of you do your own maintenance?
