Mike123456's avatar
Mike123456
2005 Fleetwood Expedition
My turn signals work ok BUT I can not hear any audible sound.
I never noticed it before as I am quite deaf but my son in law tells me it makes no sound. Is this an easy fix and if so where is the device ?
  • I removed the caps and taped over the holes with blue tape to test. No difference.
    I going to take off mirror next.
  • I wish I couldnt hear mine, constant buzzing sounding like the world is coming to an end. I was going to see if I could replace the turn signal flasher with a standard one.
  • Re the whistling on the drivers side. It may well be the drain caps, check to see if they are there and facing the correct way.
  • That noise may be from the drain slots for the driver's side window. There are supposed to be little plastic caps that prevent this noise but they fall off. Available on ebay.
    Moisheh
  • My whistling comes around the drivers side somewhere. Not always. Depends on the angle of the wind. My door has a little air noise but not a whistle.
  • Hi Big K, If you mean wind whistling around the door, then yes and the noise varies with direction of travel and wind direction. I am glad to hear that I am not the only one NOT hearing the turn signals. lol
  • I have an 05 Expy. The blinkers have never made any noise. Wish it did.
    Do you ever get wind whistling?
  • Our audible turnings signals will go MUTE if the engine brake button is on or if the brake pedal is pressed (2008 Monaco Dynasty).
    MM.
