kysurveyor wrote:
My 2005 seneca driver side slideout is haflway out. The rear part of the slide will not move, but the front half will go in and out. I previously had trouble with the fuse for that slide blowing in the control module. Any thoughts? Are there separate motors for front and back of slide? All help is appreciated.
There is only one motor for the slide. If the back is not moving than there is either something blocking it or a sheer pin has failed.
Look in the bay under the slid and see it the shaft to the rear roller is moving , if so than something is blocking the slide out from moving. If the shaft is not moving and front part is than one of the sheer pins has failed.
If a sheer pin has failed you need to figure out why the pressure to move the slide was so great as to sheer the pin.
