tropical36
Dec 15, 2017Explorer II
base1957 wrote:
2006 Alfa Gold Motorhome
Can you add an AC into the existing fantastic vent or top vent that is on the motorhome?
Trying to find a way to cool it better and would like a long term fixed solution.
So you evidently already own this rig. OK and well the mounting should be easy enough, it might take some doing for getting the wiring neatly out and where you can plug it in to a shore pedestal, using a dual power adapter and accomplished by splitting a circuit feed from the genset. This way, you can use both the genset and shore, by simply plugging or unplugging into a self installed on-board outlet. Then again, I don't know your setup, exactly, so might have to take some studying and evaluating.
38,780 PostsLatest Activity: Aug 05, 2026
