Your_Pal's avatar
Your_Pal
2006 Coachmen house batteries
First time post. I have a 2006 Coachmen Cross Country. Bought it a little over one week ago. Previous owner said he had the batteries replaced in January. Prior to that the originals lasted seven yrs.
He delivered it to our house for us. We set it up with slides out and used a heavy duty extension cord to plug it in. Watched some TV and used the interior lights while the kids did homework. No AC or heavy draw used.
Yesterday I went to pull the slides in and the batteries didn't have enough power to pull in the living room slide. RV was still plugged in and I turned the key to the right for aux. The generator didn't have enough battery to crank as well. I ended up having to turn on the RV. After several minutes I was able to turn on the generator and had enough power to pull in the slide.
The inverter was left on auto while it was parked and the key was out of the ignition. What is the correct position for the inverter. I have the remote panel that is over the door.
Any help would be great.
Thank You,
Rico
