wa8yxm
Jan 24, 2015Explorer III
Damon does have an interlock for the slides as well, Ignition on Slides disabled., Awning should auto retract, steps will not remain out but should follow door (NOTE: they will not retract when you start the MH, but will when you open/close door with motor running, and yes, I do know why).
There is a fuse, I ***THINK*** it is in the battery control center but it might be in one of the two vehicle fuse blocks. Likely the main one.
38,782 PostsLatest Activity: Sep 10, 2026
