- IvylogExplorer IIIAround 2006 they moved the fuel tank back to the second bay to decrease the weight on the front axle. I can get 15 more gallons into mine by leaning to the right and filling on the left...the bottom of the fill tube is lower than the top of the tank. I’ve but 160 gallons in a 150 tank.
- Executive45Explorer IIII don't use the small doors...just open the big ones and viola, there they are!...Dennis
- oldaveExplorerDon't be embarrassed these machines are complicated and we are all learning
On both sides you will find a small door approx. 6" sq .
They both need a key to open .
Inside those fuel doors the cap screws on and should be on a chain or cable .
Many of us tilt the coach a little with our air leveling so we can fill the
tank better .
Don't try fill both side or have the opposite cap off you can have diesel
running out on the ground .
Our engines use the same oil as the big trucks 15/40 .
Ray - LwiddisNavigatorIf that’s your only two issues, you are doing well!
- TwomedExplorerfirst bay door either side behind front wheels
15/40 Shell Rotella or delo 15/40 both good oil
Welcome...
38,782 PostsLatest Activity: Sep 10, 2026
