Montana170 wrote:
I do not have religion about shocks, but, the koni shocks on my 2006 23' Coach House seem to work fine, none of the bizarre behavior described in an earlier post.  If you are running very heavy the upwards pressure of a gas shock is probably of some benefit, it is supplementing the springs.  Because a shock can be extended or compressed by hand means nothing. The compression and release of spring and shock when hitting a bump in the road takes place in milliseconds.  If the motorhome is wallowing about, there are suspension problems. The purpose of a shock which are more accurately called dampers is to mitigate the oscillations of a spring.
YMMV
I still say the koni's are at least from my experience a waste of money !
