kerrlakeRoo wrote:
Try a couple of things,
Check nada guide for valuation info
And try
www.rvtrader.com as well as www.rvt.com
For similar units to compare.
Try the
NADA Guide Then look for the similar models on all the other sites mentioned.
My 2006 Fleetwood Tioga that I have owned for 7 years, I have encountered only small problems but nothing major. Just Routine Maintenance and the usual upkeep needed to make sure that all seams and openings are sealed and everything is tight and weather resistant ,washing, waxing, oil, filters, and fluid changes.
All of the appliances, refrigerator, stove top, oven, microwave, furnace, water heater, A/C, all have been trouble free and worked without fail. They are all the original ones that came with the RV when new, I have the sales packet from Fleetwood, and it contains all the warranty info with serial numbers and I have checked them all. Only 2 things that are not original, the on demand water pump, it was replaced by El Monte RV about a year before I bought it and the converter/charger that I upgraded to a 4 stage one.
All doors, cabinets and drawers are tight and working as they should, the fit and finish is still very good. Even all the tank sensors work! The Onan generator has been trouble free with over 900 hours on it, just routine maintenance and running it monthly under load if has not been used, to make sure that it stays that way.
Not too bad for a vehicle that is over 10 years old, being put in service as a rental for 5 years in Feb. 2006 and has over 100000 miles on it.
