RWjSIM2003
Nov 14, 2016Explorer
On many of the Bounder MH there is only one heat pump so only zone one would have heating but will blow heat out of all the vents. Same if you put it on Gas furnace it is usually controlled by Zone 1 only. Only use both Zones if using the AC's. If zone 2 shows Elec Heat or gas Furnace you have Dual Furnaces or heat pumps. Hope that helps
