Johno02
Oct 15, 2017Explorer
look for screw hole plugs on the front panel. Otherwise see if there is a back(front) cover that is removable. Find a LED that fits the opening, and in you go! Look for a LED that has a single pedestal leg, leave it on the TV, and then screw the base to the cabinet floor. Might need to add a bit of wood to raise to fit. I had to cut the front of the base off flush, but it was no problem. PM me for more details if you would like. I might be able to find some pictures.
