OldF__t
Oct 15, 2017Explorer
Remove the four snap caps underneath on the bottom and remove the four screws and the bottom itself. Remove any screws you find mounting the tv to the metal support chassis. The large bolt that is accessed thru a hole in the top of the right cabinet is a winch. Use a ratchet wrench on it to lower the tv. It is heavy so be careful.
