mhbell's avatar
mhbell
2006 Hurricane 12 volt only on shore power or Generator.
PROBLEM SOLVED
I am posting this in the hopes that it will Help and save someone else a lot of trouble. No where in the owners manual was this documented. I stumbled on it while doing a search on google. It appears that this is problem is in most if not all hurricane models and years.
My four winds hurricane 31D class A 12 volt system for the coach was only working on Shore power or generator. When not on shore power or generator I had no lights or 12 volts anywhere in the coach. The batteries had been disconnected a few days before to do some work. No wiring diagrams or schematics so I spent 3 hours tracing wires. I had no battery power to the Converter in the distribution panel. I thought that maybe it was the coach disconnect by the door. It appeared to be working. Before crawling under the motor home to look for broken wire I stumbled upon the Item below. That was the problem. when ever the coach batteries are disconnected from the battery cables this little breaker will trip. Mine was located on the right looking into the BCC. It is hard to see untill I noticed a black button about the size of a pin head. I pushed it and heard a click. Everything went to work.
Mel
Quote:
I have received the following email from Thor manufacturing, I thought I would post this in case any other fellow Four Winds owner may have the same situation, Again I thank everyone for there help.........IN THE BATTERY CONTROL CENTER LOCATED ON THE FIRE WALL ---UNDER THE HOOD --SHOULD BE RIGHT OF CENTER AND WILL SAY BATTERY CONTROL ON THE FACE --TAKE OFF THE LID YOU WILL SEE FUSES ---YOU ARE LOOKING FOR A RESETTABLE BREAKER USUALLY ON THE BOTTOM LEFT ---THIS BREAKER IS ABOUT 1.25 X.75X.75 INCHES IN LENGTH ON ONE END WILL BE A SMALL BUTTON (ABOUT THE SIZE OF A MATCH HEAD ) THIS NEEDS TO BE PUSHED IN TO RESET ---THIS WILL ALWAYS TRIP WHEN YOU CHANGE YOUR BATTERIES ---USE YOUR FLASHLIGHT AND I PROMISE YOU THAT IT IS THERE ---MANY PEOPLE SWEAR THAT IT IS NOT IN THEIR CONTROL CENTER ---BUT IT IS --JUST A BIT HARD TO FIND ....This breaker is actually oblong (the sizes stated are correct), silver in color and has a small brown button on the right hand side of it and it is on the lower right hand side of the panel. Probably will need a flashlight.
  • We had this exact issue with our 2008 FW Hurricane 34B after the house batteries died. I replaced the three house batteries and same interior electrical problem as you mentioned. I called Thor and was told the reset was under the master bed. I looked and never found a button under the bed. It was found by the mechanic to be under the hood as you described.
    Remindes me to make a label for the main breaker pannel at the master bed and one for the batt control box.
  • We found that little black button and it sorted our issue. Thanks for that tip. I had also asked Thor about this issue but they did not mention this to me. Now we have 12V working again. Thanks.
  • The recall is on much newer rigs than ours that have a very different BCC. The new BBC has much smaller disconnect solenoids that are not holing up to the power demands of the engine starter motor.
  • skrams wrote:
    This might just help me out. Thanks. My only concern is the Safety Recall 13V-265 that was issued for these units. The fix seemed to be a by-pass of the battery control centre.
    It is my understanding that the fix is to bypass a solenoid or relay that disconnects the chassis battery, not the BCC.
    Mel
  • This might just help me out. Thanks. My only concern is the Safety Recall 13V-265 that was issued for these units. The fix seemed to be a by-pass of the battery control centre.
