JackMS
Apr 25, 2013Explorer
Not sure but I would guess the sensor for the gauge would be a single wire sensor, probably with a stud and nut holding the wire on with a ring terminal. The other will be a sensor with a 2 wire plug plugging directly into it. Both should be around thermostat housing or on head. I assume you have an ISB? If so and you can't find them, I can look at mine and see if I can find them.
38,783 PostsLatest Activity: Sep 24, 2026
